How to calculate friction coefficient of turbulent flow inside a pipe
    • Devank12
      Can one explain me how to find out the friction coefficient in flow through pipe using ansys fluent???
    • Raef.Kobeissi
      {displaystyle {frac {Delta p}{L}}=f_{mathrm {D} }cdot {frac {rho }{2}}cdot {frac {{langle vrangle }^{2}}{D}},}
      Find Delta P ( Pressure inlet - Pressure outlet) and then formulate an expression in Fluent to calculate fd.
      Regards
    • atulsingh92
      A question here.
      v should be velocity magnitude, but how to obtain rho?
      Should this be from the reference value? or should be made a report first and then added to this expression?
    • Amine Ben Hadj Ali
      That is the fluid density. Its is available as post processing variable under properties.
    • atulsingh92
      Another spin off
      If the diameter (also L) is in mm (5 mm , for example)
      1) Should I mesh/scale 0.01 0.01 0.01 and then give 5 in the formula?
      or
      2) I do mesh/scale 0.01 0.01 0.01 and then give 0.005 in the formula?
      I pretty much need to do a meshscale 0.01 0.01 0.01 because every import from spaceclaim tends to not have my own dimensions.
      You give the length of your geometry along the mean stream . Check every time the scale size dimensions in Fluent.
Viewing 5 reply threads
  • The topic ‘How to calculate friction coefficient of turbulent flow inside a pipe’ is closed to new replies.
