February 18, 2026 at 4:22 pm
BALA
SubscriberHello all
I am doing Random vibration analysis of pcb with components. I want to calculate the curvature at pcb but Ansys does not give it directly so can anyone suggest is there anyway to calculate it.
February 18, 2026 at 4:58 pm
Armin
Ansys EmployeeHello,
Curvature is essentially the second derivative of displacement with respect to a path. Currently, in Mechanical, you can create results along a path, but you cannot perform operations such as taking the second derivative. Therefore, you will need to use APDL commands. Below is a test case featuring a generic PCB where curvature along a path is calculated using APDL commands. See if you can modify and utilize this for your application.
RESUME /POST1 set,first ! load the first set of results in the results file path,p1,2,10,50 ! define a path made of 2 points, store up to 10 results, 50 intermediate points ppath,1,,-160,0.8,-58.5 ! define point 1 ppath,2,,0,0.8,-58.5 ! define point 2 pdef,uymap,u,y ! map UY displacement onto path pcalc,deri,slope_x,uymap,s ! calculate first derivative of UY w.r.t. distance along the path pcalc,deri,curv_x,slope_x,s ! calculate second derivative of UY w.r.t. distance along the path /show,png plpath,uymap ! plot UY plpath,curv_x ! plot curvature /show,close -
February 18, 2026 at 5:57 pm
BALA
Subscriberthank you for your reply, i have read that in Random Vibration as displacement is RMS so taking double derivative is not correct? is it right?
February 18, 2026 at 6:23 pm
Armin
Ansys EmployeeNo problem at all.
When performing random vibration analysis, the displacement results are typically reported as root mean square (RMS) values, which represent a statistical measure of the response due to non-deterministic, broadband excitation. Calculating curvature by taking the second spatial derivative of RMS displacement along a path is a valid approach, as long as you understand that the resulting curvature is also an RMS value. However, other forum members may chime in and share their experiences.
5179
1838
1387
1249
