May 2, 2019 at 6:40 am
mitmit80
SubscriberHello,
In Mechanical, I have a model with tens of springs with the same stiffness coefficient. I want to parametrize this coefficient. The only way I figured out to do that is to first, assign a parameter to each spring in Mechanical and second, set the expression of all the parameters equal to a "master" parameter in the Parameter Set interface of Workbench. In that way, I end up with as many parameters as I have springs. I do not like it, it looks very messy to me. Is there a way to define a single parameter defining the spring constant for all the springs?
May 7, 2019 at 9:35 am
Forum ModeratorNot easily. Can you assign each a parameter and then make those parameters equal to another (dummy) parameter which you then give the value to? We can in Fluids, but that's not overly helpful here.....
May 7, 2019 at 10:48 am
mitmit80
SubscriberI wrote a script to do that, but Mechanical and/or Workbench crashes as soon as the number of parameters is more than 40-50
I use a workaround by not using at all the Parameter module of Workbench and doing everything through ACT scripts, a bit painful though.
Coming from Comsol where it is so simple to define a global parameter and use it everywhere in a model, I am perplex on why such a functionality is not implemented in Workbench.
- The topic ‘How to assign the same parameter to several components in Workbench?’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3892
1414
1256
1118
1015
