Preprocessing
Preprocessing
How to assign a unit to an imported CAD-parameter?
    • Venez
      Hi everyone!nI would like to know, how can i process an imported CAD-parameter down the line/in the workbench.nTo explain it a little bit more: after i designed the (Creo-/CAD-) part, i imported the geometry & parameter set successfully into the workbench, every parameter is dimensionless (as expected) and the meshing was done. However, i want to multiply the mesh by shifting the geometry by its width - which is available as an imported parameter. But that transformation is not possible because it needs a value/unit couple. nDo you have any suggestions? Thx in advancen
    • Keyur Kanade
      In WB, you will see parameter tab at the top. nOr you can double click on parameter in the component system. nThen you can change parameter. nPlease have a look at nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • Keyur Kanade
      Though it is not in english, but clearly shows how to change parameter in WB. n
    • Venez
      First of all, thank you for your answer (and btw: the 'not english' isn't a problem, if its my native language ^_~))nHowever, i couldn't find an answer in the videos. So i will try to explain it more - now with support of figures. While the 1st pictures is only for general understanding of the WB layout, the 2nd figure is the important one. nLet me first focus on the parameter P6 and P13. I want to specify the latter to translate/multiply the mesh in Y. The value should be identical to P6, however i cannot create a parameter connection (P13 = P6), because P13 needs a unit, which P6 has not (because its an imported CAD parameter). Likewise i cannot create a link between P2 (input parameter for CAD without unit) and P17 (imported parameter from MS Excel with unit). Of course i could create a detour by using MS Excel, where two cells have the same values but for only one of them there is a specified unit. However, i find that a little bit too much of a workaround and i hoped there is a more direct approach. nn
      This post shows how to add a length unit to a parameter.n/forum/discussion/14806/non-constant-parameter-in-ansys-mechanicaln
    • Venez
      @peteroznewmannThank you! I did not know (but hoped) that it could be so easy ^^#n
Viewing 5 reply threads
  • The topic ‘How to assign a unit to an imported CAD-parameter?’ is closed to new replies.
