October 9, 2024 at 11:49 am
ahmet.yildirim
SubscriberHi,
Firstly, please see the previous discussion: https://innovationspace.ansys.com/forum/forums/topic/how-to-apply-remote-displacement-in-ansys-apdl-2/Â
Here, I try to first way succesfully but I try to insert remote displacement to ANSYS APDL/Mechanical by Code by Interface manually. For this, there is a second way "rbe and padt and ansys" google search but how to do by this way I didnot comprehend.
I tried to model simple 100x100x10 mm^3 (X,Y,Z) block in Workbench and see ds.dat file from Solution>Open Solver Directory. The model fixed at the bottom and remote displacement inserted along +z direction by magnitude of 3 mm.
Is there any process to extract code from ds.dat file? ds.dat file can be found in this link: https://stdyildizedu-my.sharepoint.com/:w:/g/personal/ahmet_yildirim4_std_yildiz_edu_tr/EaZ7B2tIZtVHiDhgbPyGTCwB5TE2EKrjlWR5k6RqqV_0sQ?e=mdzzNa
As special, I try to apply remote displacement in the time step of 2. Here is a some code I extract from ds.dat file (from another example block):
time,2
nblock,3
(1i9,3e20.9e3)
   24130    2.026135417E+03    1.230935777E+03    1.099999994E+02
*set,tid,3
*set,cid,2
et,cid,174
et,tid,170
keyo,tid,2,1Â Â Â Â Â Â Â Â Â Â Â Â Â Â ! Don't fix the pilot node
keyo,tid,4,111111
keyo,cid,12,5Â Â Â Â Â Â Â Â Â Â Â Â Â ! Bonded Contact
keyo,cid,4,1Â Â Â Â Â Â Â Â Â Â Â Â Â Â ! Deformable RBE3 style load
keyo,cid,2,2Â Â Â Â Â Â Â Â Â Â Â Â Â Â ! MPC style contact
eblock,10,,,2124
nsub, 40, 100, 40allsel
*DIM,_loadvari39uz,TABLE,3,1,1,TIME
! Time values
*TAXIS,_loadvari39uz(1),1,0.,1.,2.
! Load values
_loadvari39uz(1,1,1) = 0.
_loadvari39uz(2,1,1) = 0.
_loadvari39uz(3,1,1) = 4.
CMBLOCK,REMOTEDISPALL,NODE,       1
(8i10)
    24130
esel,all
/gst,on,on
fini
*get,_numnode,node,0,count
*get,_numelem,elem,0,count
*get, _MAXELEMNUM, elem, 0, NUM, MAX
*get, _MAXNODENUM, node, 0, NUM, MAX
*get, _MAXELEMTYPE, etyp, 0, NUM, MAX
*get, _MAXREALCONST, rcon, 0, NUM, MAX
OUTRES, ALL, ALL
lswrite, 2"""
Is there any way to "Apply Remote Displacement in ANSYS APDL by Code or Interface"?
I am looking forward to any response.
Thanks a lot.
Ahmet YILDIRIM
October 9, 2024 at 7:57 pm
harshvardhan.negi
Ansys EmployeeHi,
There are a few similar discussion on forum, see if these help you out:
Remote displacement on Ansys Mechanical APDL
Remote Displacement using APDL (ansys.com)
Harshvardhan -
October 10, 2024 at 6:14 am
ahmet.yildirim
SubscriberHi Harshvardhan,
I extract a code from discussions,
nsel,s,loc,z,110
CM,P1,NODE
d,P1,uz,4"""
But this is like a normal displacement just grouping them and then appl a disp.Â
Trying to do:
For a wall, which has a thickness of 110 mm, I try to select all nodes at this z=110 mm and then apply remote displacement at the middle of the wall (LxH let's say).
How to rerrange the code, if you could see?
Thanks,
AY
5674
1890
1419
