August 18, 2021 at 2:47 am
TYUST10086
Subscriberhow to apply pressures to the surfaces with specific directions in static ANSYS APDL environment,such as in the Y derection.
August 20, 2021 at 8:56 amEmperor
August 20, 2021 at 1:31 pmAshish Khemka
Try using the SFE command:
SFE (ansys.com)
This is what Mechanical does (only a small portion of the input file is shown here) to apply pressure of 1MPa at a face in X, Y and Z directions:
esel,s,type,,2
nsle
sfe,all,1,pres,1,1.
sfe,all,2,pres,1,1.
sfe,all,3,pres,1,1.
nsel,all
esel,all
Regards Ashish Khemka
August 20, 2021 at 2:05 pmdlooman
Ansys EmployeeSurface effect elements are required. See the description of Face 5 for surf154.
Viewing 3 reply threads- The topic ‘how to apply pressures to the surfaces with specific directions in static ANSYS APDL environment.’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3882
1414
1241
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
