Electronics
Electronics
how to apply excitation function other than importing dataset?
    • Nouran Muhammad
      I am currently doing spinal cord stimulation in Maxwell 3D. I want to apply a voltage waveform with the following parameters on some electrodes:
      Frequency: 500 Hz
      Peak amplitude: 5 volt
      Pulse width: 250 microseconds
      Is there a way to apply the excitation function i want other than generating it outside maxwell and importing it as a dataset?
      The waveform i want to generate looks like this (the signal goes on and off - has a duty cycle):
    • DELI
      hi, yes, you can import dataset as excitaiton in Maxwell using pwl function, please visit Maxwell manual for more details.
  • The topic ‘how to apply excitation function other than importing dataset?’ is closed to new replies.
