May 14, 2024 at 3:16 pm
Sneha E S
SubscriberI am doing fatigue analysis for reinforced beam with fixed end and simply supported end as two different cases to study the failure pattern. I am planning to provide cyclic load from 0 to 50 kN for a number of times on the two points shown in the figure till the structure fails, how can IÂ achieve this?
May 15, 2024 at 1:25 pm
Daniel Shaw
Ansys EmployeeIf you have SN or EN fatigue properties and the analysis is linear, you can use the Mechancial Fatigue Tool (FT) with history data loading or Ansys nCode DesignLife with time series or time step loading.
- The topic ‘How to apply cyclic load on two points on an RCC beam?’ is closed to new replies.
1890
1419
