TAGGED: compression-only-support, mechanical, supports
November 4, 2024 at 7:27 am
November 4, 2024 at 10:17 am
harshvardhan.negi
Ansys EmployeeÂ
Compression only support works by creating a frictionless contact with a rigid surface. This rigid surface is not modelled geometrically.Â
So, the surface scoped for compression only support can be assumed to be in a frictionless contact with a rigid body. It can slide and separate, but not go through the rigid surface.If you select the walls of the hole for this support, it will be modelled as if a rigid pin with zero tolerance is inserted inside the hole.
More information on compression-only support can be found in the following links:
17.6.3.6. Compression Only Support
Structural Boundary Conditions | Ansys Innovation Courses
compression only and bearing supportI hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines) -
November 4, 2024 at 11:07 am
M210098
SubscriberHi,
If that is the case, is there a need to also apply frictionless contact? Or we can just apply one? As they both have the same function.Â
November 4, 2024 at 11:10 am
harshvardhan.negi
Ansys EmployeeHi,
To apply frictional contact, you will need 2 bodies that will come in contact. Compression only support can be applied with only one body.
In this case, you don't need to apply frictionless contact if you are applying compression only support.Regards,
Harshvardhan
Ansys Help
November 4, 2024 at 11:22 am
M210098
SubscriberHi,
Thank you for the clarification.
November 4, 2024 at 11:55 am
ErKo
Ansys EmployeeHi
Just to add we have a whole free course on contacts:
https://innovationspace.ansys.com/product/contact-mechanics/Hope this helps
Erik
6064
