TAGGED: ansys-workbench, fatigue, fatigue-life, fatigue-load
October 25, 2021 at 6:18 am
DhruvP
SubscriberI am doing fatigue analysis of agitator nozzle of pressure vessel in ansys in which I have certain type of loads given in tabular data. i cant figure out how to apply these loads in order to get correct results in ansys workbench.
I have Axial force, Lateral force, Bending moment and Torque given in data with min, max, static, start and average values for each of these force and moments.
October 27, 2021 at 9:58 pmdanielshaw
Ansys EmployeeYou cannot use the Mechanical Fatigue Tool (FT), because this type of loading would be non-constant, non-proportional loading which is not supported. You need to Time Step loading in Ansys nCode DesignLife.
November 9, 2021 at 10:22 amDhruvP
SubscriberThank you for the guidance. however I have no experience in Time step analysis in Ansys nCode Design Life. Can you explain how it is done in Ansys or how should i approach this kind of problems ??
November 15, 2021 at 3:50 ampeteroznewman
SubscriberPlease explain how the values in the table should be applied. Are the Max and Min values supposed to be added to the Stat Value? The Average seems to be the average of the Max and Min values, so that seems to be a redundant piece of information. What is the point of the Start value? Is that ever returned to in the fatigue cycles.
It would be clear if you would create a table of values that describe one cycle.
Viewing 3 reply threads- The topic ‘how to apply certain type of loading conditions for fatigue analysis in Ansys workbench.’ is closed to new replies.
