August 2, 2024 at 12:34 pm
alexandre.gomes
SubscriberHi,
I am trying to apply Thermal load using the command BF, Node.
I have a number of csv files, with two columns, column 1 is the node number and column 2 is the temperature.
I intend to import and read the tables using the following commands:
/Inquire, nLinFil, Lines, C:\xxxx\yyyy.csv
*dim, yyyy, Table, nLinFil, 1, 1
*TRead, yyyy,     C:\xxxx\xxxx.csv
Normally i create a component that includes the nodes but in this case i would like to apply a different temperature value to each node (110000 nodes in total).
Is there a way to do this?Â
Thank you!
August 5, 2024 at 1:46 pm
mrife
Ansys EmployeeHi Alex1EDP
Yes, see the publically available Mechanical APDL help here. Essentially when defining the load instead of a value the table name is substituted and is enclosed in % characters. Mike
August 5, 2024 at 3:45 pm
dlooman
Ansys EmployeeIn this case, the *dim command would be *dim,yyyy,Table,110000,,,NODE The primary variable NODE indicates that column zero of the table (column 1 of your csv file) are node numbers. Then as Mike says, you input the table array by entering it in quotes: BF,ALL,TEMP,%yyyy%
5799
