March 26, 2024 at 4:54 am
Hyeokbae kwon
SubscriberI am a student studying magnetic active soft material (MSM).
I would like to implement a matrix containing magnetic particles that is deformed by an external magnetic field.
In most studies, MSM is interpreted as a user defined subroutine in Abaqus. (https://doi.org/10.1016/j.jmps.2018.10.008)
Is this possible with Ansys? Should I buy Abaqus for this study?
April 1, 2024 at 6:44 pm
HDLI
Ansys EmployeeHello Hyeokbae kwon,
   Could you check the Maxwell online help manual on magnetostriction and inverse magnetostriction ?, inÂ
   1). magnetostriction and inverse magnetostriction
   2). magnetostriction coupling in workbench
HDLI
- The topic ‘How to anaylsis Magnetic active soft material’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1363
1194
