How to adjust for Volumetric Locking affects?
    • kirstenbraun
      Hello all,
      I am currently busy with developing a 3D model of a tyre in ANSYS Mechanical.
      MODEL DETAILS
      The following are the connections. The frictional contact has a friction coefficient of 0.64 which is the frictional coefficient between rubber (tyre tread) and stainless steel (road).
    • Ashish Khemka
      nnPlease refer to the link below, which shows different element technologies and the integration options available. I will close the other discussion you have posted as it looks the same.nnnRegards,nAshish Khemkan
    • kirstenbraun
      , nUnfortunately I do not have access to the link you sent as I have access to my ANSYS license though my university. Is there any way you could attach the information with no access limitations? Thank you n
    • Ashish Khemka
      Hi Array ,nnPlease use the following link to access the Ansys Help:nn ,nnPlease use the following link to access the Ansys Help:nnnRegards,nAshish Khemkan
  • The topic ‘How to adjust for Volumetric Locking affects?’ is closed to new replies.
