January 25, 2024 at 7:40 am
D L
SubscriberHi everyone, I am trying to study the effects of a moving body on the pressure drop of a fluid flowing within the moving body. The moving body should be undergoing rigid body motion. I have tried many ways to simulate this but I am having trouble getting it to work properly. I will list the methods I have tried thus far below.
Method #1:
I created a DEFINE_ZONE_MOTION UDF that models constant acceleration and added it to "mesh motion" in "cell zone conditions" for my solid. I then used a transient solver to be able to capture the difference in velocity with respect to time. This worked well for lower acceleration values for a while but as I increased the acceleration, the pressure drop started to remain constant, which should not be the case. I tried reducing time step and overall transient time but neither solved this issue.
An example of the UDF used is this:#include "udf.h"
 DEFINE_ZONE_MOTION(acceleration_2_neg,omega,axis,origin,velocity,time,dtime)
 real a = 2.0;
 real cruise = 60.0 / 3.6;
 real currentvelo; if (time <= cruise / a)
 currentvelo = a * time * -1.0;
 else
 currentvelo = cruise * -1.0;
 } N3V_D (velocity,=,currentvelo,0.0,0.0);
 return;
}Â
Method #2:
I tried to add a constant translational velocity to "mesh motion" in "cell zone conditions" for my solid. The problem with this is that no matter what magnitude I put as the velocity, the outlet pressure of the fluid remains constant as well.
Method #3:
I tried using a DEFINE_GRID_MOTION UDF and attached it to the solid via dynamic mesh. However, I can't get this to run at all because I will encounter a negative cell volume issue. I am reluctant to use dynamic mesh too because it would take way too long to process.Â
Are there other possible ways to add rigid body motion to a solid? My mentor suggested to simply use boundary conditions to add a constant velocity to the solid wall but I cannot find any way to do this directly within the software.
Any help will be greatly appreciated, thank you in advance!Â
January 25, 2024 at 11:09 am
Forum ModeratorIf the body is moving at a constant speed what is driving the fluid flow? Please can you post some images of what you're wanting to model?
January 25, 2024 at 11:54 pm
January 26, 2024 at 10:14 am
Forum ModeratorHow does the solid motion alter the flow?Â
- The topic ‘How to add velocity or acceleration to solids?’ is closed to new replies.
