November 26, 2021 at 6:58 am
gaurav_shrivas15
Subscriberhi,
I am trying to do simulation of curing analysis where with respect to time chemical reaction will build up.
but I am not able to use customized solid reaction in fluent.
the aim is to find degree of cure
can anyone know how add reactions of solid to get degree of cure?
Thanks in advance
November 26, 2021 at 11:37 amRob
Forum ModeratorIs that a surface reaction (to a CFD solid) or a process where the fluid solidifies (phase change). CFD definitions of fluid and solid can be a little different to the experimental equivalent.
November 26, 2021 at 12:39 pmAmine Ben Hadj Ali
Ansys Employeethat solid chemical component need to be considered in Fluent as "fluid" but having the "solid" specie flag. We have a standard tutorial dealing with CVD which describes the steps to solid species defined (as well as site species "place-holder").
November 27, 2021 at 5:25 amgaurav_shrivas15
SubscriberIt is a volumetric reaction. Initially, Materials are in a semi-solid state (Slurry or paste type). once they are mixed together reaction will start and the resulting product will get hardened. I want to check how this reaction will complete at 60 degrees Celsius temperature.
Can you tell me how to approach this problem?
November 27, 2021 at 5:27 amgaurav_shrivas15
SubscriberCan you tell me what is CVD and where to find this standard tutorial as I am new to this forum?
December 1, 2021 at 8:06 amAmine Ben Hadj Ali
Ansys Employeewherever you are in Fluent "hit" F1, The online help opens, Then navigate to the Fluent Tutorials and search the surface chemistry tutorial.
Viewing 5 reply threads- The topic ‘how to add solid material chemical reaction in fluent’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3967
1425
1272
1119
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
