February 3, 2020 at 8:34 pm
atulsbhat
SubscriberCan we directly add 50 point property Table Without manually typing all Properties in individual Boxes ? As it becomes a very time consuming and a lengthy procedure. I have My properties in a text File, like this
633.00 9099.6
633.10 9125.9
633.20 9152.5
633.30 9179.3
633.40 9206.5
633.50 9234
633.60 9261.8
633.70 9290
633.80 9318.5
633.90 9347.3
634.00 9376.5
634.10 9406
634.20 9435.9
634.30 9466.1
634.40 9496.7
634.50 9527.7
634.60 9559.1
634.70 9590.9
634.80 9623
634.90 9655.6
635.00 9688.6
635.10 9722
635.20 9755.9
635.30 9790.2
635.40 9825
635.50 9860.2
635.60 9895.9
635.70 9932.1
635.80 9968.7
635.90 10006
636.00 10044
636.10 10082
636.20 10120
636.30 10160
636.40 10200
636.50 10240
636.60 10281
636.70 10323
636.80 10365
636.90 10408
637.00 10451
637.10 10495
637.20 10540
637.30 10585
637.40 10631
637.50 10678
637.60 10726
637.70 10774
637.80 10823
637.90 10873
638.00 10924
638.10 10975
638.20 11027
638.30 11081
638.40 11135
638.50 11190
638.60 11246
638.70 11303
638.80 11360
638.90 11419
639.00 11479
639.10 11540
639.20 11602
639.30 11665
639.40 11730
639.50 11795
639.60 11862
639.70 11930
639.80 11999
639.90 12070
640.00 12142
640.10 12215
640.20 12290
640.30 12367
640.40 12445
640.50 12524
640.60 12606
640.70 12689
640.80 12773
Kindly Look into this issue, as i have to manually add properties in 200 data points (4*50 points of Properties)
Regards
February 4, 2020 at 5:59 am
Amine Ben Hadj Ali
Ansys EmployeeYou create a script or just a sample for the related scheme file. -
February 7, 2020 at 2:29 pm
atulsbhat
SubscriberSir Is The format of Script or Sample for Scm Files, available in The Manual, Especially Creation of A
. Scm file for Piecewise Linear data feeding for Properties of material? -
February 7, 2020 at 2:30 pm
Forum ModeratorNot scheme you want a journal file.Â
February 7, 2020 at 9:34 pm
atulsbhat
SubscriberSir,
Can You Guide me through the Script/format of a Journal file for adding 4 Thermophysical Properties (4*50 = 200 Property Data Points) ?
I looked into the manual, but It didnt have any information about creating Property Journal File ( I Just want a example format which i must type, Example Format)
Can You Provide me The Format (script to be written)Â for atleast 2 Data points? I will do it for rest of the data points in a similar manner
Regards
February 8, 2020 at 6:04 am
Amine Ben Hadj Ali
Ansys EmployeeIn material panel save a dummy material by just clicking on user defined material database give a name and copy a material from case. Open the datsdata and modify it or see how it's written.
Alternative is to use C or C++ to read the materials array and assign properties via UDF. -
March 11, 2020 at 11:47 pm
atulsbhat
SubscriberI tried It Sir, Apart From Typing Manually All Properties , I Didnt Get a Better alternative,
Help me Out On This.
I want To add properties Via Piecewise Linear. UDF didnt Work out for me.
Thanks
March 12, 2020 at 6:18 am
Amine Ben Hadj Ali
Ansys EmployeeHave you followed the examples from UDF manual?
- The topic ‘How To Add material properties using piecewise linear,without manual typing for each Temperature?’ is closed to new replies.
4818
1587
1386
1242
