June 6, 2019 at 7:25 am
HorstvanGrass
SubscriberHello,
I would like to use a third temperature range from the thermo.db file, imported by the chemkin interpreter. As is it explained by the documentation I added for O2 the following lines to the file:
Code:
O- 90589O 1E 1 G 0300.00 5000.00 1000.00 1
0.02559580E+02-0.07147887E-03 0.03301804E-06-0.06660944E-10 0.04900726E-14 2
0.11489346E+05 0.04426186E+02 0.02747263E+02-0.05724860E-02 0.02712548E-05 3
0.02691511E-08-0.02002357E-11 0.11443947E+05 0.03469852E+02 4
O2 121386O 2 G 0200.00 3500.00 1
TEMP 0200.00 1000.00 2500.00 3500.00
0.30563941E+01 0.89059362E-03-0.20849917E-06 0.24115927E-10-0.10516720E-14
0.37260112E+04 0.44780081E+01
0.34298433E+01-0.25250392E-03 0.80470663E-06-0.33336490E-09 0.43425671E-13
0.37097800E+04 0.26751302E+01
0.37695923E+01-0.59256858E-03-0.21359336E-06 0.13644331E-08-0.63575666E-12
0.35908836E+04 0.78130486E+00
O2- 121286O 2E 1 G 0300.00 5000.00 1000.00 1
0.03883013E+02 0.07407872E-02-0.02961776E-05 0.05724304E-09-0.04086547E-13 2
-0.07121644E+05 0.02658211E+02 0.02872291E+02 0.03359716E-01-0.02664886E-04 3
0.09807524E-08-0.16709571E-12-0.06829094E+05 0.07938372E+02 4
Also in the TUI Command line I executed:
Code:
(rpsetvar 'species/chemkin-import-type 3)
But when file is loading I receive an error at the TEMP declaration. I'm using fluent18.0 by the way.
Thanks for any help and advise -
June 6, 2019 at 12:51 pm
DrAmine
Ansys EmployeeThis is not supported in R18.0
June 6, 2019 at 1:43 pm
HorstvanGrass
SubscriberThanks for your reply. Do you know which version is compatible?
Best Regards -
June 11, 2019 at 2:31 pm
DrAmine
Ansys EmployeeVersion later this year probably.
June 13, 2019 at 6:58 am
HorstvanGrass
SubscriberThx
Viewing 4 reply threads
- The topic ‘How to add a third temperature range in chemkin thermo file’ is closed to new replies.
1890
1414
1304
