January 14, 2024 at 2:22 am
1317794602
SubscriberHow to add a spring device between the two structures of AQWA, so that it will receive force when compressed or stretched
January 15, 2024 at 4:51 pm
Shuangxing Du
Ansys EmployeeYou can define a linear cable with the Unstretched Length to be zero.
January 16, 2024 at 1:56 am
1317794602
Subscriberthanks But cable compression doesn't apply force
January 16, 2024 at 9:46 am
Shuangxing Du
Ansys EmployeePlease run the two files below, you could find the force on the spring is non-zero for these two cases of which the constant forces (defined by FORC data record) are in the opposite directions.
(1) ABT001.DAT
OB T001 LIBR STAT
TITLE point mass with a zero unstretched spring
OPTIONS PBIS REST END
RESTART 1 5
01 COOR
01 1 0.0 0.0 1.0
01 2 0.0 0.0 2.0
END01
02 ELM1
END02PMAS (1)(1)(1)(1)
02 FINI
03 MATE
END03 1 10.0
04 GEOM
END04PMAS 1 20.0 0.0 0.0 20.0 0.0 20.0
05 GLOB
05DPTH 250.0
05DENS 1025.0
END05ACCG 9.806
06 FDR1
06PERD 1 6 18.0 17.0 16.5 16.0 15.0 14.0
06PERD 7 7 12.0
END06DIRN 0 5 -180.0 180.0
07 NONE
08 NONE
09 NONE
10 NONE
11 NONE
12 NONE
13 NONE
14 MOOR
* INITIAL DISTANCE BETWEEN TWO ATTACHMENTS IS ZERO, UNSTRETCHED LENGTH IS ZERO
14LINE 1 1 0 1 1.0E5 0.0
14FORC 1 1 0 2 -1.0E3
END14
15 NONE
16 LMTS
16MXNI 20
END16MERR 0.01 0.01 0.01 0.01 0.01 0.01
17 NONE
18 PROP
END18PTEN(2) ABT0002.DAT
JOB T001 LIBR STAT
RESTART 1 5
01 COOR
01 1 0.0 0.0 1.0
01 2 0.0 0.0 2.0
END01
02 ELM1
02 FINI
03 MATE
END03 1 10.0
04 GEOM
05 GLOB
05DPTH 250.0
05DENS 1025.0
END05ACCG 9.806
06 FDR1
06PERD 7 7 12.0
07 NONE
08 NONE
09 NONE
10 NONE
11 NONE
12 NONE
13 NONE
14 MOOR
14FORC 1 1 0 2 1.0E3
END14
15 NONE
16 LMTS
16MXNI 20
17 NONE
18 PROP
END18PTEN -
January 16, 2024 at 10:34 am
1317794602
SubscriberOf these four hinge points, you can run time domain analysis if you open three of them, but four will report an error, how to solve this
January 16, 2024 at 10:35 am
January 16, 2024 at 10:38 am
January 16, 2024 at 10:41 am
1317794602
SubscriberOn the far right is a buoy, in the middle is an approach bridge, and on the left is a wall
January 16, 2024 at 4:02 pm
Shuangxing Du
Ansys EmployeeYour model has redundant constraint. To avoid the error, please do
(1) if the top and bottom bridges are modelled by two structures, defineing two ball/sockets to link bridges and buoy, defining two hinges to link bridges and wall.
(2) if the top and bottom bridges is modelled by one structure, defineing one hinge between wall and bridge structure, and defining another hinge between bridge structure and buoy.
January 17, 2024 at 1:54 am
1317794602
Subscriberthanks!
January 26, 2024 at 3:30 am
1317794602
SubscriberHello, I have created a hinge joint. When analyzing the force, how can I determine the direction of XYZ? Is this force direction in the original coordinate system(FRA)
January 26, 2024 at 3:37 am
January 26, 2024 at 5:00 am
1317794602
SubscriberIs the force acting on the hinge point the force acting on the hinge point or the force it exerts on the structure
January 26, 2024 at 10:23 am
Shuangxing Du
Ansys EmployeeThe force and moment act on the hing point as Joint Forces, these force/moment provide the force and moment as Structure Force, Articulation Sum Only with respect to the COGs of the linked structures. As shown below both the joint force and the articutation sum force on the linked structure can be displayed in Aqwa Workbench.
January 26, 2024 at 10:31 am
1317794602
SubscriberDoes this result indicate the positive or negative force on the hinge point or the positive or negative force on the structure from the hinge point
January 26, 2024 at 10:38 am
Shuangxing Du
Ansys Employeeyes, you are right.
January 26, 2024 at 11:00 am
1317794602
SubscriberDoes this direction represent the direction in which the hinge point gives force to the structure?
January 26, 2024 at 11:57 am
Shuangxing Du
Ansys EmployeeYes, it is represented in the global fixed axes.
January 26, 2024 at 12:38 pm
1317794602
Subscriberthanks
January 29, 2024 at 10:32 am
1317794602
SubscriberHello, my wind speed in AQWA was imported into an Excel file, and the wind speed has a duration of 10800 seconds. As wind speed can cause changes in flow velocity, how should I set this flow velocity based on this wind speed
January 29, 2024 at 11:21 am
Shuangxing Du
Ansys EmployeeThe effect of wind on the ocean current could be the topic of the oceanic and atmospheric study. Could you please find some solutions on the problem, and define the corresponding current velocity in Aqwa analysis?
January 29, 2024 at 11:43 am
1317794602
SubscriberI want to set the flow rate to change over time. Can this aqwa be achieved
January 29, 2024 at 12:35 pm
Shuangxing Du
Ansys EmployeeI am sorry that it may not possible to set the current to change over time in Aqwa. But you may run several time durations, the current are different between different durations.
February 7, 2024 at 2:03 am
1317794602
SubscriberI want to study the forces acting on the two hinge points on the right in the XYZ and RX directions. This requires limiting the movement of the middle two floating bodies in the RX direction. So, how do I add hinges to these four hinge points? I have used two BALLs and two hinges, but I cannot study the force in the Rx direction. Thank you for your answer
February 7, 2024 at 9:10 am
Shuangxing Du
Ansys EmployeeIt is a statically indeterminate configiration. Aqwa could provide the precise structural responses of these floating bodies and bridges, but may not give the accurate reaction forces on the redundant hinges.
- The topic ‘How to add a spring device between the two structures of AQWA, so that it will r’ is closed to new replies.
5744
