How to add a result to a design point without updating
    • EugeneKalentev
      Suppose we have a project in which several design points. We solve this project. Next, we will open the results for the current design point (for example, Mechanical) and add some result as a new parameter. Then this parameter will be automatically added and its value will be indicated. At the same time, for the rest of the design points this does not occur, updating with recalculation is required. Why is that? Is it possible to do this without updating all design points?
    • Keyur Kanade
      yes, it would require updating the project. i am afraid we can not do it without updating it.
    • EugeneKalentev
      I understood. thanks for the answer
    • Keyur Kanade
      if this helps you, please mark this post as 'is solution' to help others on forum.
    • EugeneKalentev
       did it
      At the same time, I believe that this functionality should be implemented. If the calculation is carried out for a long time and then you add some result to the design points, you will have to wait until everything is recalculated.
Viewing 4 reply threads
  • The topic ‘How to add a result to a design point without updating’ is closed to new replies.
