How to activate a newly added command to previous ANSYS versions?
    • elhamasadi
      Is it possible to add a new command to previous AANSYS versions?nI already have ANSYS 2019-R3 installed on my computer, but I need to use CLoad command to apply cyclic load on my model which is introduced in 2020 versions.n
    • Ashish Khemka
      nCan you try running the command in the previous version and see if it work? It may be unsupported for the previous version but may work.nnRegards,nAshish Khemkan
    • elhamasadi
      nI tried your suggestion but it didn't recognize the commandn
    • Ashish Khemka
      nnIf the previous version does not recognize the command then you will have to proceed with the latest version.nnRegards,nAshish Khemkan
    • elhamasadi
      nthanksn
Viewing 4 reply threads
  • The topic ‘How to activate a newly added command to previous ANSYS versions?’ is closed to new replies.
