December 3, 2019 at 2:30 am
SU252019
SubscriberI currently am trying to obtain a flow simulation result that shows boundary-layer flow separation at a sharp edge, however the contours I generate do not show my intended result. Most of my CFD simulations do not show any or very little boundary-layer activity in the desired region. Is there a specific tool in ANSYS / FLUENT that would help capture the region in a flowfield where flow-separation occurs in a turbulent flow?Â
Thank you!
December 3, 2019 at 3:35 pm
Forum ModeratorCan you post images of the solution and mesh? You need to make sure you have everything set correctly: you may not have separation.Â
December 3, 2019 at 3:47 pm
December 4, 2019 at 12:02 pm
Forum ModeratorFrom what I can see of your mesh you need to review the documentation on inflation and mesh size control: it looks far too coarse to pick up much of anything.Â
- The topic ‘How to accurately model flow separation of air at sharp inlet-edge’ is closed to new replies.
5669
1890
1419
1304
