April 13, 2025 at 5:20 pm
arnabj.borah
SubscriberI'm running a transient thermal simulation in Fluent that started at 14°C. After running for a while, temperature reached 16°C, and I saved the case and data files before stopping. When I reopened these files to continue the simulation, the report definitions only show data starting from 16°C (where I left off).I know my complete solution data should be stored in the files since the case/data files were properly saved. However, I can't figure out how to access the full temperature history from the initial 14°C through the current state.What's the correct way to extract the complete temperature history spanning the entire simulation when you've stopped and continued in Fluent?
April 14, 2025 at 8:55 am
Forum ModeratorFluent doesn't retain data other than values at the current time step. If you have monitors it's common to save these to file, so when you resume the run Fluent will append (usually) and you may want/need to display in Excel or similar.Â
- acces to path ‘session_files’ is denied error
- unexpected license problem; exiting. hit return to exit.
- Ansys Student 2025 R1 – Ansys Discovery did not install
- No FlexNet Publisher (FNP) license found for feature HPC Parallel.
- Ansys Electronics Desktop crashes when trying to set the steel type in RMXprt
- Can not find Spaceclaim option in ANSYS2024R2 workbench
- Workbench application not showing up after installing Ansys Student 2024 R2
3019
970
857
761
599
