November 28, 2023 at 2:30 am
zhou1219302
SubscriberVerify
WHILE PROCESSING FILE BASED INPUT(/INPUT OR MACRO)AN ERRORHAS OCCURRED. SHOULD INPUT PROCESSING BE SUSPENDED?
When I import the CBD File into APDL,I encounter the problem.
November 28, 2023 at 3:27 pm
mrife
Ansys EmployeeHi Yu
Identify the error; figure out where in the input file the import was at the time of the error; address the input files mistake/typo/whatever. Â
The APDL command "C***,comment text" (without the quotes) will place a comment in the MAPDL output. If it is not obvious where in the input file the issue is located then you can start adding comments to the cdb file with text that would make sense to you. Â
January 25, 2024 at 11:55 am
ErKo
Ansys EmployeeClosing.
- The topic ‘How solve the following problem?’ is closed to new replies.
1890
1419
