May 5, 2021 at 7:28 am
choongcym
SubscriberI am running a simulation of foot stepping on the ground. Below shows the force convergence graph and it had stucked at 1% for few days, can i know what are the issues through the force convergence graph?
Thank you.
May 5, 2021 at 8:36 amErik Kostson
Ansys EmployeeHello
That is really impossible to answer (how long it takes).
It all depend on how many nonlinear iterations you have (more for longer problems and that are hard to converge), and how long each nonlinear iteration takes (the larger the model the more it can take), and of course if we use multiple cores, hpc, ... and many other factors.
In the end of the day you should see in the task manager that the apdl solver is running taking some memory, and that your force convergence graph is gradually updated and so on. So to see that it is actually still solving. As for the graph it looks like the load is applied a bit too fast at the start and hence the bisection (red vertical lines) cutting back the load in order to converge.
All the best
Erik
May 6, 2021 at 5:37 amchoongcym
SubscriberThank you Erik.
March 23, 2023 at 7:52 amMohammed vaseem
SubscriberÂ
iam running a simulation in the mechanical and its been almost 25 minutes and its still stuck at 10% how much time it takes to solve, static structural and standard earth gravity in horizontal z axis and 1.5g acceleration on x and y axisÂ
March 24, 2023 at 1:11 ampeteroznewman
SubscriberThe guidance given on May 5, 2021 seems helpful.
Viewing 5 reply threads- The topic ‘How long does it take for Ansys to solve a complex model?’ is closed to new replies.
3597
1283
1117
1068
983
