February 2, 2024 at 7:39 am
Yiqing zhang
SubscriberY+ needs to be calculated when drawing the grid, so the value of the feature length needs to be known. I want to know whether the feature length of open channel flow is calculated by hydraulic radius or hydraulic diameter? Can you give specific formulas for reference?
February 2, 2024 at 11:15 am
Forum ModeratorYou also need to avoid excessive aspect ratios when looking at VOF. So inflation meshes tend not to be recommended.
February 12, 2024 at 6:49 am
Yiqing zhang
SubscriberYou didn't answer my question, did I not describe clearly enough?I want know
how is the characteristic length of open channel flow calculated?
February 12, 2024 at 10:23 am
Forum ModeratorIn much the same way as it's calculated in any other model. However, y+ is very much not the only criteria to worry about hence my comment. Depending on what the open channel is you may also want to think about how wall roughness interacts with the near wall cell.
I'll also remind you about the T&Cs. Specifically sections regarding politeness. Written language is often misunderstood, so extra care should always be taken.
- The topic ‘How is the characteristic length of open channel flow calculated?’ is closed to new replies.
5649
1885
1404
1303
