November 11, 2025 at 6:18 pm
Syed Saif Ali
SubscriberCould you please guide us on how floating licenses can be used across systems in different locations?
We have a client who currently has two named-user licenses. He uses these across four systems but only needs to run them on a maximum of two systems concurrently. Since he plans to switch to floating licensing, we want to understand the best setup for him.
Will a VPN connection work for accessing the floating license server remotely? The client currently does not use a VPN, so we would also appreciate your advice on recommended options for this scenario.
Viewing 0 reply threads
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
1493
1375
1197
