May 12, 2022 at 4:51 pm
shashank1
SubscriberI simulated a basic transmission line and got good s11 and S21 but when I looked at Z parameters it says Real(Z) = 0 ohm which makes no sense. Does HFSS calculate Z- parameters in a different way?
May 16, 2022 at 11:50 amPraneeth
Please note that there is a differential microstrip line example and go through it to see if your simulation model is set up correctly.
You can also go through this link - Ansys Electronics 2022 R1 - Post Processed S-Matrices for detailed information on your query.
All the very best Praneeth.
Viewing 1 reply thread- The topic ‘How does HFSS calculate Z parameters’ is closed to new replies.
4703
1565
1386
1242
