July 29, 2024 at 7:13 am
thomason-sanchez
SubscriberHello, I am currently working on Discovery and I saw that the discretization in Explore Mode is made with voxels and the calculation are made with the GPU solver. Is it possible to have further explanation on Explore Mode ?
Thanks in advance.Â
July 29, 2024 at 10:55 am
Devendra Badgujar
Forum ModeratorHi Thomas,Â
You can refer this What simulation technology does Ansys Discovery use in Explore mode? - Ansys Knowledge artcile. You can go through the courses shown below to get more understanding on Explore mode:
Structural Simulation Using Ansys Discovery | Ansys Courses
Fluid Flow Simulation Using Ansys Discovery | Ansys Courses
If you have any specific question, or are facing issues with any feature let me know and I can help.Â
Devendra
August 2, 2024 at 7:36 am
thomason-sanchez
SubscriberHi Devendra,Â
Thanks for your answerÂ
Is it possible for Explore Mode to be more accurate in some cases than Refine Mode even with local refinement.
For instance, in cases where the velocity < 1 Mach or for simple/small geometry. I did some simulation and I don't know when to choose Explore or Refine ModeÂ
- The topic ‘How does Explore Mode work ?’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
- Inconsistent Script
4607
1510
1386
1209
