July 3, 2023 at 8:45 pm
Alex S
SubscriberHello, I'm trying to understand how anyss mechanical handles a 2 parameter mooney rivlin material, where the incompressibility parameter is defined as 0. While I understand it is not ideal to have d1=0, I have seen in the literature a number of models doing so. Can anybody point me to somehwhere in the ansys documentation that can explain how this is handelled by ansys?Â
July 4, 2023 at 2:48 pm
Ruturaj Gavali
Ansys EmployeeHey Alex!
Please see if the following links are helpful:
11.6. Hyperelasticity (ansys.com)
4.6. Hyperelasticity (ansys.com)
8.15.6. Formulation and Parameters for a Hyper Elastic Material (ansys.com)
Thanks!
For more information, check out the following links:
July 4, 2023 at 9:11 pm
Alex S
SubscriberHello,Â
Thank you for your response, I'm unable to access the links provided. I have tried the instructions found here:
/forum/forums/topic/how-to-access-the-ansys-online-help/ and I am still unable to access them.ÂÂ
Many thanks,
AlexÂ
July 5, 2023 at 10:13 am
Ashish Khemka
Forum ModeratorHi Alex,
The steps indicated in the link you shared should work. Can you please share snapshots of the issue you are facing?
Also, please refer to the following links as well:
Mooney-Rivlin Models (ansys.com)
Incomprehensibility parameter of hyperelastic material (ansys.com)
Why are all incompressibility parameters = 0 when I use ANSYS curve fitting?
Ashish Khemka
July 5, 2023 at 7:06 pm
Alex S
SubscriberHello,Â
I have now managed to open the links, however I couldn't find an answer to what I was trying to find out from the documentation. In ansys if I define a mooney-rivlin hyperelastic material (per the equation below) with a d=0, this would be the result of the materal being incompresisble.However in the mooney rivlin 2 parameter equation this would result in a calculation where 1 is divided by 0, which gives an undefined value. So my question is, what is ansys using inplace of the "undefined" value in this scenario?Â
- The topic ‘How does Ansys deal with d1=0 in a two parameter mooney rivlin material?’ is closed to new replies.
5694
1891
1419
