how does ansys calculate these values please in radiation model
    • AGAAMAZ
      hello everyone ,
      please i want to know how ansys calculates these values in radiation model as shown in picture
      and for example after 1 hour of transient solution how it calculates the ambient temperature ( T_amb )
      Click on the Help button and see what the Theory Guide tells you. nAmbient temperature is something you need to define:the solar model is there to give a direction and magnitude, not to replace you setting up all the external boundary conditions. n
    • AGAAMAZ
      thank you for your reply sir, i will see the guide nbut i want to know somethingndo you mean that i have to enter the temperature at each hour at that day to ANSYS and ANSYS calculates based on it ?n
      Which temperature are you referring to? n
    • AGAAMAZ
      nFor example if the ambient temperature at 6 AM = 12 C , at 7 AM = 17 C , and continue increasing till it reaches 40 for example nhow can i insert this to ansys to use it in calculation ?ni saw the Theory Guide it tells that :nDirect normal solar irradiation is computed using the ASHRAE Fair Weather Conditions method, when this option is selected in the solar calculator. Note: Equation 20 and Table 7 from Chapter 30 of the 2001 ASHRAE Handbook of Fundamentals.nnbut what about ambient temperature how ANSYS deals with it ?.n
      That's what you add as a boundary condition depending on the options you choose. Ie convective losses through the glass. n
Viewing 5 reply threads
  • The topic ‘how does ansys calculate these values please in radiation model’ is closed to new replies.
