May 18, 2022 at 7:52 am
Pixie
SubscriberI'm running a chemical vapor deposition simulation with 3 mass flow inlets (kg/s). Knowing the surface deposition rate on the reaction zone is useful in my case. But how does calculate the surface deposition rate (kg/m^2s)?
Thanks
May 18, 2022 at 8:45 amRob
Forum ModeratorHow are you modelling the deposition? ie surface reaction, particle impingement?
May 18, 2022 at 8:48 amPixie
SubscriberYes, using surface reaction.
May 18, 2022 at 12:28 pmRob
Forum ModeratorHave you seen the tutorial? https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/flu_tg/x1-27200017.html
July 17, 2023 at 3:58 amHilmi Johari
SubscriberAre there any other link other than the link given to access how the surface deposition rate is calculated? I cannot access the link. A reviewer wanted to know exactly how it is calculated.
Thank you.
July 17, 2023 at 8:34 amRob
Forum ModeratorIf you click on Help in the solver you'll get to the documentation. Then paste that link into another tab in that browser window. The solvers provide the cookie/token/biscuit that bypasses the password checks.Â
Viewing 5 reply threads- The topic ‘How does Ansys calculate the surface deposition rate (kg/m^2s)?’ is closed to new replies.
5754
