How do you define monitors in Fluent
    • zedstomper
      While I see a monitor tab I dont see something to monitor moment. Im looking for Moniters > momentnnIm also looking to define a second monitor for plotting volume average of velocity magnitude. Any help would be appreciated.n
    • Karthik Remella
      Administrator
      Hello,nYou should be able to specify the moment from: Solution -> Reports -> Definition -> New -> Force Report -> MomentnRegarding a monitor for velocity: Solution -> Reports -> Definition -> Surface Report -> Area weighted averagenKarthikn
    • zedstomper
      Hello,You should be able to specify the moment from: Solution -> Reports -> Definition -> New -> Force Report -> MomentRegarding a monitor for velocity: Solution -> Reports -> Definition -> Surface Report -> Area weighted averageKarthik/forum/discussion/comment/110546#Comment_110546
      Thank you Karthik it worked!n
    • Karthik Remella
      Administrator
      Excellent!n
  • The topic ‘How do you define monitors in Fluent’ is closed to new replies.
