February 28, 2017 at 9:25 am
Nikita
Ansys EmployeeCan I use the Wrap around target tool to take planar curves or text and wrap them onto planes, cylinders, and cones?
September 18, 2017 at 10:19 pm
pgl
Ansys EmployeeThe Wrap around target tool allows you to take planar curves or text and wrap them onto planes, cylinders, and cones...
You may choose a surface target or establish a direction for the wrap. Curves can be wrapped onto geometry with per-existing imprinted wrapped curves. Surfaces may be used for wrapping, however only the surface edges are used to wrap around the target.
To wrap a curve, text, or a surface around a target object: >Click the Project tool >Check ON the Wrap around target option >Click the curve, text or surface you want to wrap >Click the Select Direction tool guide and choose a direction, you will see purple lines on the target as a preview >Click the Complete tool guide or press the "Enter" key
August 23, 2023 at 10:12 am
Jayesh
SubscriberIs it possible to wrap surface to cylinder using Ansys workbench?
Requested you to kindly do the needful.
- The topic ‘How do I use the Wrap around target option in the Project tool?’ is closed to new replies.
5809
