March 22, 2021 at 3:17 pmzedstomperSubscriberHi I am working on a mixing vessel and would like to view plots of the moment and velocity. I believe I have that set up now. I previously right clicked fluent >update and the simulation converged after about 300 iterations. I have not been able to see this info again.nHow do I rerun the simulation and have the charts pop back up? Then how do I view these charts after I close them?nI would also like to view a velocity gradient of a plane at different time iterations if anyone knows how to do this after it runs. I have the plane and contour already set up. Thank you.n
March 22, 2021 at 4:10 pmRobForum ModeratorYou need to save the case and data and then open the relevant files up to view that data. By default, Fluent only saves when you tell it to, and the data file will only contain data from that time step. n
- The topic ‘How do I rerun a simulation and view post analysis charts?’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
594
591
540
366
