February 15, 2018 at 4:38 pm
_rob
SubscriberAn image of what I'm trying to do is shown below. Basically, I have an open 9 ft^3 enclosure with a 5" high floor vent at normal lab conditions. A hydrogen source is somewhere on the bottom of the enclosure, and the top is either fully open with no roof or has a cover with a hole in it. I want to model the path hydrogen takes to escape the enclosure. How do I create the solid bodies in order to mesh this properly, and how do I mesh it properly?Â
February 16, 2018 at 8:00 am
February 16, 2018 at 9:05 am
_rob
SubscriberThanks for the reply.
I'm new to all of this, so please bear with me. Â
Why use the default mesh instead of using a setting which would yield a more uniform, cuboid mesh? Isn't the goal to have as uniform a mesh as possible?
Thanks in advance.
February 19, 2018 at 9:29 am
Vishal Ganore
Ansys EmployeeYes. you can do so. Many factors comes in. How your physics is setup, How much efforts to put in, Quality of produced mesh (default vs. cuboid), will it cause any difference to results? area of interest etc.
You could get started with this default one and then playground with other factors.Â
- The topic ‘How do I mesh this properly?’ is closed to new replies.
4597
1495
1386
1209
