3D Design
3D Design
How do I import a CAD model from Solidworks into ANSYS with shared topology?
    • quocho7982211
      I already tried making a multibody part in SW, but when importing into ANSYS, it is still seen as 2 separate bodies with automatic contact between the two parts.n
      The only way to get Shared Topology is to use either SpaceClaim or DesignModeler. If you have one of those, they can open a Parasolid from SolidWorks, then you can create a Multibody part and Share Topology.nIf you don't want to do that or don't have those licenses, then you can imprint the larger face with the outline of the smaller face to get idendtical faces, then use Mesh Controls to get a congruent mesh on both faces, and finally to use Mesh Merge. That ends up being equivalent to Shared Topology, but is more work.n
  • The topic ‘How do I import a CAD model from Solidworks into ANSYS with shared topology?’ is closed to new replies.
