Electronics
Electronics
How do I fix intersection errors within a PCB in Icepak?
    • Novedgnik
      When I check to validate my Icepak simulation. There are two separate intersections errors that c ome from the dielectric with the ground plane and a Voltage node. The design requires those items to be intermixed with each other, but I am unable to run an icepak simulation until those two points are fixed on the dielectric. What are some techniques to fix intersection errorsn
    • Praneeth
      HiArray,nPlease share screen shots of your simulation model using the upload image option to help us serve you better. Make sure you share the screenshots of the overlapping regions of the dielectric with ground plane and voltage node and the associated error messages from the message window. nAll the best.nBest Regards,nn
    • VivekKamble
      nPlease check the box as shown below,nGo to Icepak tab -> Design Settings -> Validations and check the following boxes.nI hope this will help to resolve this problem.nThanks,nVivekn
  • The topic ‘How do I fix intersection errors within a PCB in Icepak?’ is closed to new replies.
