March 6, 2024 at 11:31 am
Alexandru Banica
SubscriberI constructed a model in Solidworks for a filtre that filtres microparticles found in the air - the model is very basic at this stage-. I am using Fluid flow Fluent. The simmulation seems to be showing me something, but my problem is that not all the air that enters the inlets come out of the outlets - see attached picture. My question is how can I setup the simmulation so it shows me the exact trajectory of the air that comes inside the filtre.
I am a total begginer at using ANSYS, even if you can reffer me to some learning materials it would be much appreciated. Thank you so much in advance.
March 6, 2024 at 1:46 pm
SRP
Ansys EmployeeHi,
To understand the trajectory of air inside the filter, you can use the pathline visualization in ANSYS Fluent. pathlines are a great way to visualize the path that a fluid element will take through the domain.
Please check Ansys video:
- The topic ‘How do I find out the correct trajectory of air particles.’ is closed to new replies.
6745
1324
1067
