how do i extract nodal displacements at each node at all time steps in transient analysis (workbench
    • mayakuntla92
       i am working on wave propagation analysis in Ansys workbench
    • jpasquerell
      Use of a command object under solution is one way.  Start with:
      /post1
      set,first
      *get,nres,active,,set,nset   ! number of results sets
      *get,ndmx,node,,num,maxd
      *dim,nodaldisp,array,nres,ndmx*3           ! for translation only or 6 if rots are needed
      then a do loop cycling through the result sets with *vget commands of the three nodal displacements.  See *MWRITE for output of the parameter to a file.
    • prasannakumar92
      SET,FIRST
      NSEL,S,NODE,,141475,142273   !!!! 800 nodes
      NODENUMBER = 141475       !!! initial node number
      *DO,KK,1,800,1
      *VGET,RES,NODE,NODENUMBER,V,Y,,,4
      *CFOPEN,'MYFILE','CSV'
      *VWRITE,'NODAL','VELOCITIES'
      %I, %G
      *SET,NODENUMBER,NODENUMBER+1
      *ENDDO
      *CFCLOS
      is my code correct??? please help me out
    • prasannakumar92
       i want only displacements in y direction....
    • prasannakumar92
      SET,LIST
      *DIM,VELY,ARRAY,3125,800  !!!!! FOR 800 NODES AT 3125 TIME STEPS
      NODENUMBER=141475          ! INITIAL NODE NUMBER
      *CFOPEN,VEL,CSV
      *DO,KK,1,800,1
      *VGET,VELY(1,KK),NODE,NODENUMBER,V,Y,,,4
      *VWRITE,VELY(1)
      (E15.8)
      NODENUMBER=NODENUMBER+1
      *ENDDO
      *CFCLOSE
      another code to extract results at 3125-time steps
      I am unable to write results to CSV file instead it is writing all zeros
      any help will be appreciated???
Viewing 4 reply threads
  • The topic ‘how do i extract nodal displacements at each node at all time steps in transient analysis (workbench’ is closed to new replies.
