November 7, 2024 at 8:48 am
November 7, 2024 at 11:23 am
Forum ModeratorThat's boundary adaption. So don't use inflation and once in the Fluent solver you refine the mesh. I'd use Boundary registers.Â
November 7, 2024 at 12:23 pm
ae22b001
SubscriberHi, thanks for the reply.
I think that works, but could you maybe tell me how to do it in ICEM? I'd like to have more control over the sizing.
In this thread, they explained how I might be able to do it in Ansys Meshing using Multipart (Link to Ansys Forum Thread), could you tell me how to do a similar thing in ICEM?Â
Thanks -
November 7, 2024 at 1:19 pm
Forum ModeratorIt's a coarser base mesh that is adapted in the Fluent solver.Â
November 7, 2024 at 1:26 pm
November 7, 2024 at 1:36 pm
Forum ModeratorYou would need to set all of the sizes manually and would finish up with a nonconformal mesh. It can be done but it's a lot of work and unnecessary zone linking in the solver.Â
November 7, 2024 at 5:15 pm
November 7, 2024 at 5:56 pm
Forum ModeratorYes, that's why I said to use a single coarse mesh and adapt. You need to look at nonconformal interfaces: you can't have an interior with the model you have.Â
November 8, 2024 at 4:40 am
ae22b001
SubscriberGot it! Thanks for your help
November 15, 2024 at 1:03 pm
ae22b001
SubscriberHi so i tried to refine an existing mesh near the wall to reduce its ascept ratio. I wanted to split the cells into 2 to reduce its aspect ratio. To do that i set the minimum edge length to a value that is greater than the height of the cell. I expected it to only be refined in the other direction. However, it still splits the cell into 4, retaining its Aspect ratio. I split the zone into 2, to see a comparison of before vs after.Â
How do I get it to split into 2 cells and not 4? Is that possible?
November 15, 2024 at 1:24 pm
Forum ModeratorAdaption doesn't work like that. You can increase the wall adjacent cell with anisotropic inflation but not do what you want.Â
6795
1343
1152
