TAGGED: modal, modal-analysis, modal-simulation, mode-shapes, mode-superposition
May 4, 2022 at 8:37 am
RS3
SubscriberHi,
I am currently performing a fatigue analysis, where I need the modal coordiantes for further tasks. I am getting the modal coordinates with the command: TRNOPT, Msup, 3, , , 1
Now I want to add the line "END_OF_HEADER" after the header, as I need it for further simulations.
Is there a way to edit this file in Ansys Workbench? Till now I add that line manually and afterwards start the following simulation.
Thank you for your answers.
May 5, 2022 at 5:25 pmdanielshaw
Ansys Employeeno, you cannot edit the file in Mechanical.
Viewing 1 reply thread- The topic ‘How do I change the mcf file containing the modal coordinates?’ is closed to new replies.
