July 4, 2024 at 9:55 am
ZacarÃas Conde Teruel
SubscriberGood afternoon everyone,
I'm trying to simulate a displacement of a radial band to compress radially a semisphere. This band is modeled with an internal radius equal to the external radius of the eye but it has really a lesser radius so the idea is to model the pressure that the band apply to the sphere as a result of trying to recover its real radius.Â
I have created a cylindrical coordinate system and I have modeled firstly as a displacement of the internal surface of the band that is in contact with the external surface of the sphere but it doesn't get a result. Secondly, I have calculated the pressure it apply as p = E * (R - r )/ r where E is the young modulus of the band and R y r are the external radius of the sphere and the real radius of the band (that it wants to recover). The problem in this second analysys is that it gets a excessive displacement compressing the sphere in a irreal manner.
July 10, 2024 at 11:52 pm
mjmiddle
Ansys EmployeeÂ
A radial displacementy should work by setting the x value of a displacement that uses a cylindrical coordinate system, as long as rotation does not occur around the cylindrical Y axis. But it seems by the shape, you would really want a spherical direction for displacement, and Mechanical doesn’t allow you to create a spherical coordinate system.
You seem to be describing a press fit model. We don’t handle these by prescribing a fixed radial displacement. We model press-fit two ways:
- Model the geometry in the dimensions before assembly. When the bodies are placed together, there will be an interfence and you will use a contact. The analysis will deform both bodies into touching status, and in so doing, it computes the press-fit stress and strain. The interference should be within the first layer thickness of the volume elements at the contact.
- Model geometry as touching, and specify an offset distance in the contact Details that would be the interference distance of the assembled bodies before press-fit occurs. The analysis will deform the geometry and compute stress/strain just like method 1.
- The topic ‘How do I apply a radial displacement to an element to compress another element’ is closed to new replies.
5589
1885
1403
1298
