November 1, 2017 at 9:57 pm
Tareq
SubscriberPlease I need to know how can we measure the viscosity of the fluid but it does not show in Results?
November 1, 2017 at 10:09 pm
Raef.Kobeissi
SubscriberYou usually define the viscosity of a fluid before you run the simulation, unless you define it as a finction of temperature (polynomial function for example). If you do that then you can easily get the temperature data and create a function to calculate the viscosity in Fluent or CFD Post.
I invite my other colleagues to share any other ideas!
Cheers -
November 2, 2017 at 7:55 pm
- The topic ‘How can we measure the visocity of fluid’ is closed to new replies.
.jpg?width=690&upscale=false)
