December 19, 2024 at 12:08 pm
2020221038
SubscriberThe aerodynamic and hydrodynamic loads calculated by aqwa are based on the center of gravity. How can this load be transferred to APDL and turned into a load based on the structure as a whole? For example, pressure loads, concentrated forces, accelerations, etc.
January 3, 2025 at 12:39 pm
Yu Bi
Ansys EmployeeThe Hydrodynamic Pressure Add-on can help map the hydrodynamic pressure into the Static Structural model. More information can be found in the Aqwa User's manual section 8.1. https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v242/en/wb_aqwa/aqwa_extensions_hydro_pressure.html
May 9, 2025 at 2:45 am
2020221038
SubscriberOkay, thanks! I've benefited from your answers.
1885
1403
1303
