July 31, 2020 at 2:44 pm
Keyur Kanade
Ansys EmployeeHow can I tell whether my flow is laminar or turbulent?
prajput
Ansys EmployeeHello @kkanade
The Reynolds number parameter determines whether the given flow is laminar or turbulent. Laminar flow occurs at low Re (where the viscous forces are dominant) and is characterized by smooth fluid motion. Turbulent flow, on the other hand, occurs at high Re (where the inertia forces are dominant) and is characterized by chaotic fluid motion with lots of mixing and eddies.Â
July 31, 2020 at 2:45 pm
Karthik Remella
AdministratorYou can use the following ranges as reference to understand if your flow is laminar, turbulent or transitional. However, they are not hard limits. The transition can happen earlier or later depending on surface smoothness and other factors.Â
For an internal flow:
Re < 2300 - The flow is laminar
Re > 4000 - The flow is turbulent
For extenal flow:
Re<1x10^5Â Â - The flow is laminar
Re>5x10^5Â Â - The flow is turbulent
Keyur Kanade
Ansys EmployeeThanks you all for your quick replies! @prajput @Kremella
I have another question, how can I calculate the Reynolds number?
prajput
Ansys EmployeeThe Reynolds number is mathematically defined as:
Re = (rho * V * L) / mu
where,
rho is the fluid density
V is the fluid velocity
L is the problem characteristic length scale
mu is the fluid dynamic viscosity
August 4, 2020 at 2:38 pm
Forum ModeratorDon't forget to read up on the Rayleigh Number for buoyant flows.Â
- The topic ‘How can I tell whether my flow is laminar or turbulent?’ is closed to new replies.
- affinity not set
3977
1461
1272
1124
