October 12, 2020 at 7:52 am
lukas.vonberg
SubscriberHi, nI am running a simulation in FLUENT 2020 R2 on Windows 10. I used 'File->Write->Start transcript' to write the console output to a txt-file. Then I copied the folder containing the case-file to start another simulation, however i didn't tell Fluent to stop the transcript before. Now, whenever i start the simulation in the copied folder, Fluent writes a transcript file (as i have long simulations the file gets very big, up to 5 GB). I am not able to tell Fluent to stop writing the transcript file. When I try to stop the transcript, Fluent tells me that there is no active transcript-file. When i start a new transcript, Fluent writes the output to both files. When i stop the new transcript, Fluent continues to write to the 'old' file.nIs there any way to solve this problem? I already did many modifications to the copied case-file so I would not like to go back to the old case or to set up a new case from scratch.nThanks in advance,nLukasn -
October 12, 2020 at 9:16 am
DrAmine
Ansys EmployeePlease switch off that option of writing transcript under File>Preferences>General.n -
October 12, 2020 at 1:22 pm
lukas.vonberg
Subscriberthanks for the fast reply, it worked perfectlynn
- The topic ‘How can i stop Fluent from writing to a transcript file?’ is closed to new replies.
Ansys Innovation Space
1283
1117
1068
983
