May 30, 2020 at 10:05 pm
afrizalmahendra
SubscriberI have a problem with my ANSYS R1 2020. When i click solve it doesn't work and shown an notification "An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes".Â
After i checked Solver Output in Solution Information it displayed 2 warnings:
 *** WARNING ***                        CP =      0.375  TIME= 04:49:19
 Temperature-dependent properties have not been specified. The        Â
 THOPT,QUASI option does not perform equilibrium iterations. Small    Â
 time steps may be required to obtain accurate results.                Â
 SOLVE is not a recognized PREP7 command, abbreviation, or macro.      Â
 This command will be ignored.                                        Â
 *************** Write FE CONNECTORS *********
What's actually wrong with my ANSYS and why it can't work to solve my transient thermal simulation? What should i do next to fix this problems? Anyone can help me? Thanks
January 8, 2021 at 3:01 pm
abi151994
SubscriberDid you solve the error? I am facing the same issuen
- The topic ‘How Can I Solved Error in Workbench 2020 R1?’ is closed to new replies.
4633
1540
1386
1225
