October 14, 2021 at 6:03 pm
andremendes
SubscriberHi, I instal ansys 2020R2 and the workbench and all the rest of the programs seem to work fine but when i try to open Fluent through the workbench it says it failed due an error. When i try to open just the Fluent is gives me this error (image)
October 28, 2021 at 1:37 pmGeorge Karnos
Tracking down program crashes from DLL issues is very tricky. There is a Microsoft tool called "procmon" that is free to download that will monitor all the low level system calls while it is running. You could run that then try to run Fluent or CFX until it fails then turn off capturing in procmon otherwise it will keep on logging system calls. You can look in the process tree and filter on just the tree items for Fluent/CFX and see what DLLls they have loaded. Or maybe search for "system32" to see what DLLs got loaded from system32.
October 28, 2021 at 1:41 pmGeorge Karnos
Ansys EmployeeIn another case we had seen that it was xerces-c_3_2.dll that was causing the issue.
Viewing 2 reply threads- The topic ‘How can i solve this error from Fluent?’ is closed to new replies.
