February 6, 2019 at 4:08 am
Keyur Kanade
Ansys EmployeeTo renew ANSYS student version license without changing the version or performing a new installation, please use following steps.Â
- Go to
https://www.ansys.com/academic/free-student-products
Then download one of the following three packages available on this page
Discovery Live Student : STUDENTDISCOVERY_###_WINX64.zip
ANSYS AIM Student : AIMANSYSACADEMICSTUDENT_###_WINX64
ANSYS Student : ANSYSACADEMICSTUDENT_###_WINX64.zipÂ
Note: Any package and any version that is currently available on the page is OK.
- Unzip the package that you just downloaded, then look for the folder named ‘student’
- In this ‘student’ folder, you will see WINX64.7z . Extract (‘unzip&rsquo
this file
- Go inside the unzipped WINX64Â -> Shared Files -> Licensing -> Here, you will see 'student.lic' file
 -Copy this 'student.lic' file to where ANSYS is currently installed on your machine default location to replace your old ‘student.lic’ file in your installation directory.
October 6, 2019 at 1:40 pm
Ananth Narayan
SubscriberIs there any possibilities of getting only licences file instead of downloading of Giga Bytes of file for a KB file.
February 12, 2020 at 6:40 am
Ajith
SubscriberHow to update the license? I couldn't find the analysis system in the toolbox. Is this an error due to the license? I am currently using the student version. Someone please help me with this.
February 12, 2020 at 11:41 am
Forum ModeratorRead the OP. Also don't multi-post.Â
May 5, 2020 at 4:39 am
Alvin
SubscriberHi guys.. I just have a question. For example i download ansys student 2019 R2 again and replace my old 'student.lic' file with a new one... since the built-in license for R2 is only until 05/30/2020, does that mean that it will still be the deadline even if I already replaced the old 'student.lic' file??? Thank you.Â
May 24, 2020 at 3:40 pm
uconcorde
SubscriberSame question as stated by Alvin. Please help. Thank you in advance.
June 17, 2020 at 10:33 am
Forum ModeratorYes, you'll need 2019R3 or 2020R1 to extend the licence.Â
June 20, 2020 at 3:52 am
Baswa17
SubscriberPlease tell me di u get the ans for this question. Do we need download whole Gb file just for KB file
June 21, 2020 at 10:28 am
faizadaughter
SubscriberHi....I downloaded and installed Ansysacademic 2020R1..How can I buy Student license ..It is showing in programme list of Window 10 but not opening...How it will be run …...Earlier this I used Ansys version 15.0 which was running properly ….Guide please
June 23, 2020 at 4:22 pm
Yolandevis
SubscriberHi,Â
I have download and installed Ansys student 2020R1, Follow all the steps accordingly but its still fails to see/recognise the license.
can someone please help me.Â
June 26, 2020 at 10:22 am
ThePhontyfex
SubscriberHi, I have the same problem of Yolandevis. I download Accademic Ansys two days ago and the first time I open, it work, but from the second time it tell me that "mechanical editor does not have a valid license". I try to re-install the program and to replace "student.lic" but does non work. Please help me.
July 6, 2020 at 7:31 pm
uconcorde
SubscriberHi, so it means that there is no way to keep using the old version once the license expired. We have to download and install the new version for a valid license?
August 24, 2020 at 4:02 pm
awoloye.warmate
SubscriberI've tried the above process to renew my ANSYS 2019R2 version but to no avail. Now that I've uninstalled and deleted all ANSYS app in my laptop, can any new version work for my previously simulated projects? nCan I reinstall 2019R2 n -
August 25, 2020 at 10:09 am
Forum ModeratorOld projects should read into the newer versions of the code; make sure you read the messages as the model loads in case any defaults are different. n -
August 28, 2020 at 11:58 am
imranalif
SubscriberHi Win,nThanks, it works for me ! nI replaced 'student.lic' file on my 2020 R1 with 2020 R2 and restart my laptop then it's good to go.nThanksn -
August 29, 2020 at 3:29 am
imranalif
Subscriber[update]nIt happened again.nI installed the latest version and works fine.nWhen I quit and run fluent same issue happen in 2020 R2n -
September 1, 2020 at 7:21 pm
tsiriaks
Ansys EmployeeCan you post the screenshot of the issue inline with text ?nIf you check the student.lic file, when is the expiration date ?n -
January 28, 2021 at 10:29 am
January 30, 2021 at 5:31 pm
behm0001
SubscriberPlease help i have same issue as tookai nn -
February 1, 2021 at 7:37 am
Imran_Ahmed
SubscriberI have the same problem as cant find the 'student.lic' file in ansys 2021 R1Can you guys help us ?n -
February 1, 2021 at 10:51 pm
chadam
SubscriberSame here with 2021, cant find the license filen -
February 2, 2021 at 9:57 am
Sam254
Subscribern -
February 4, 2021 at 10:01 am
chadam
SubscriberCome on its a shame it cant be solved, I cant use Fluent because of this.n -
February 4, 2021 at 10:44 am
Forum ModeratorYou could use 2021R1! nIt's covered here /forum/discussion/19805/how-to-renew-ansys-student-product-licensenn -
March 27, 2021 at 10:57 pm
jsprunger8
SubscriberI am trying to do this with the 2020 version. I download the files for the 2021, extracted them, I go to student, then unzip the WINX64.7z. However, the only file in there is a folder called licensingclient , and inside of that. Just a file labeled .acldata n -
March 29, 2021 at 10:16 am
Forum ModeratorIt changed for 2021R1, there is a sticky in the Student Software section. The 2020R2 licence is valid until about August. n -
June 28, 2022 at 5:38 pm
purnalingam.revathi
SubscriberHow to find the customer numer(account number ) ?
October 16, 2022 at 8:55 am
hbilal1076
SubscriberThank you for sharing such a great technique of solving the issue, it woked for me.
- The topic ‘How can I renew ANSYS student version license?’ is closed to new replies.
3977
1461
1272
1124
