December 21, 2024 at 10:02 am
merveala01
SubscriberI have plate heat exchanger that passes through in cold water fluid and hot water fluid. but I can't get a reasonable cold water output according to the hot water inlet temperature. For example the hot water inlet is 50 degree cold water inlet is 20 degree but the cold water outlet is like 21. I dont understand. I must find at least 40 degree. I did share topology in spaceclaim. But they dont look like 1 layer. I gave wall thickness 0.001m. mass flow inlet pressure outlet. what else can ı do?
December 23, 2024 at 10:18 am
Forum Moderatorhttps://innovationspace.ansys.com/forum/forums/topic/how-can-i-do-plate-heat-exchanger-analysis-please-help/Â Posting into multiple threads isn't going to speed things up, but does waste Moderator time.Â
- The topic ‘How can I regular walls and shadows?’ is closed to new replies.
6730
1319
1047
